Festool
Festool MFT-HZ 80 Lever Clamp for MFT & MW1000
SKU: 108325
£43.98
£36.65 Excl. VAT
  • Easy to use, self-locking, cam action, quick-release
  • Fits any bench with 20mm dog holes
  • Provides quick and secure surface clamping of the workpiece
Whether you call it a lever clamp, surface clamp, hold down clamp or bench clamp, the MFT-HZ 80 does its intended job perfectly. This cam action lever clamp allows you to secure workpieces on to the MFT and the MW1000 mobile workshop. It will fit into any 20mm dog hole in a multifunction workbench or track saw table.
The wide flat lever makes it simple to operate using one hand. Any workpiece; up to 80mm thick, round or flat can be securely clamped onto your bench top. This fast cam action surface clamp can be used anywhere you can drill a 20mm diameter hole. It is ideal for machining workpieces of any size and shape, for example when sanding, planing, drilling, gluing, etc.
Dimensions (L x W x H): 130 x 40 x 155mm, maximum height of workpiece: 80mm.
Manufacturer Part Number 577132
Web Attribute Set Router Table Accessories
EAN Barcode 4014549395240
