Festool
Festool S 75/4 FSG/5 Jigsaw Blades Extra Stable Wood Cuts (Pkt 5)
SKU: 930216
£14.58 £15.58 Save £1.00
£12.15 Excl. VAT
  • Extra stable blade, particularly well suited for straight cuts when using the guide rail
  • For cuts in softwood/ hardwood, untreated chipboard, coated chipboard & veneered blockboard
  • Cross-set teeth, conically ground for quick cuts in exact angles
  • Blade length 75mm, Max cutting depth 55mm
  • Supplied as pack of 5
Extra stable blade, particularly well suited for straight cuts when using the guide rail . Suitable for softwood/ hardwood, untreated chipboard, coated chipboard and veneered blockboard. Cross-set teeth, conically ground for quick cuts in exact angles. Supplied in pack of 5.
Jigsaw Blade Length 75 mm
Max Cutting Depth 55 mm
Manufacturer Part Number 499476
Web Attribute Set Jigsaw Blades
EAN Barcode 4014549189344
