The Festool TCT (Tungsten Carbide Tipped) circular saw blades offer a perfect combination of cutting performance and quality results. Manufactured in accordance with Festool’s uncompromising standards, they have generous carbide tips ensuring a long working life. These 216mm blades fit the Festool KS60 compound sliding mitre saw, but can of course fit any saw able to take this size. The TF64 features 64 teeth designed for cutting aluminium panels and profiles, Perspex, hard and fibre-reinforced plastics, non-ferrous metals and aluminium composite panels.
Festool
Festool TCT Saw Blade Aluminium/Plastic - 216mm x 2.3mm x 30mm 64T
| Blade Diameter | 216 mm |
| Maximum RPM | 5,000 rpm |
| Manufacturer Part Number | 500122 |
| Kerf | 2.3 mm |
| Teeth | 64 |
| Tooth Format | TCG |
| Plate Thickness | 1.6 mm |
| Hook Angle | 0 |
| Bore Size | 30 mm |
| Web Attribute Set | Circular Saw Blades - Power Tool |
| EAN Barcode | 4014549212219 |
