The Festool TCT (Tungsten Carbide Tipped) circular saw blades offer a perfect combination of cutting performance and quality results. Manufactured in accordance with Festool’s uncompromising standards, they have generous carbide tips ensuring a long working life. These 216mm blades fit the Festool KS60 compound sliding mitre saw, but can of course fit any saw able to take this size. The W60 features 60 teeth, designed for clean, splinter-free crosscuts in solid wood as well as coated or veneered panels.
Festool
Festool TCT Saw Blade Fine - 216mm x 2.3mm x 30mm 60T
| Blade Diameter | 216 mm |
| Maximum RPM | 5,000 rpm |
| Manufacturer Part Number | 500125 |
| Kerf | 2.3 mm |
| Teeth | 60 |
| Tooth Format | ATB |
| Plate Thickness | 1.6 mm |
| Hook Angle | 5 Negative Rake |
| Bore Size | 30 mm |
| Web Attribute Set | Circular Saw Blades - Power Tool |
| EAN Barcode | 4014549212240 |
