A 160 x 20mm Festool saw blade suitable for the TS55 plunge saw, with a 2.2mm kerf. This blade has 48 teeth with a triple chip grind giving you a fine cut on laminate costed boards, HPL (High Pressure Laminate) melamine resin boards (Trespa ®), mineral materials, acrylic glass and phenolic-resin-bonded fibre and fabrics.
Festool
Festool TCT Saw Blade Laminate/HPL - 160mm x 2.2mm x 20mm 48T
| Blade Diameter | 160 mm |
| Maximum RPM | 9,500 rpm |
| Manufacturer Part Number | 496308 |
| Kerf | 2.2 mm |
| Teeth | 48 |
| Tooth Format | TCG |
| Plate Thickness | 1.6 mm |
| Hook Angle | 4 |
| Bore Size | 20 mm |
| Blade Application | Laminate Board (48 teeth) |
| Web Attribute Set | Circular Saw Blades - Power Tool |
| EAN Barcode | 4014549120583 |
