Festool
Festool TCT Saw Blade Rip 168mm x1.8mm x 20mm 16T
SKU: 109096
£32.98
£27.48 Excl. VAT
  • 1.8mm thin kerf saw blades for maximum performance
  • Cut faster and achieve a perfect result
  • Aggressive hook angle for rapid rip cuts
This high tech, high spec blade ensures the job gets done faster and with a better result. These new generation of thin kerf saw blades are designed to give maximum performance. The 1.8mm thin kerf saw blade and tooth geometry allows you to work faster, reduces the load on the machine.
The blade teeth are high-quality carbide resulting in a long service life. The tooth format is alternate bevel (ATB) with an aggressive 20 hook angle and large gullets for fast rip cutting in solid wood. These blades fit the Festool TS 60 plunge-cut saws and the CSC SYS 50 Table Saw.
Blade Diameter 168 mm
Maximum RPM 9,500 rpm
Manufacturer Part Number 205763
Web Attribute Set Circular Saw Blades - Power Tool
EAN Barcode 4014549390368
