210 x 30mm Festool saw blades suitable for the TS75 plunge saw. A general purpose medium cutting blade with 36 teeth, 2.4mm kerf.
Festool
Festool TCT Saw Blade Universal - 210mm x 2.4mm x 30mm 36T
| Blade Diameter | 210 mm |
| Maximum RPM | 6,500 rpm |
| Manufacturer Part Number | 493198 |
| Kerf | 2.4 mm |
| Teeth | 36 |
| Tooth Format | ATB |
| Plate Thickness | 1.8 mm |
| Hook Angle | 15 |
| Bore Size | 30 mm |
| Blade Application | General Purpose (36 teeth) |
| Web Attribute Set | Circular Saw Blades - Power Tool |
| EAN Barcode | 4014549044964 |
