Festool
Festool TCT Saw Blade Universal - 216mm x 2.3mm x 30mm 36T
SKU: 103648
£67.98
£56.65 Excl. VAT
  • 36 teeth, 216mm diameter, 30mm bore
  • Excellent general purpose saw blade
  • Alternating teeth with a medium chip angle
  • Designed for cutting every type of wood and wood composite
  • Suitable for building panels, gypsum fibre boards and soft plastic
The Festool TCT (Tungsten Carbide Tipped) circular saw blades offer a perfect combination of cutting performance and quality results. Manufactured in accordance with Festool’s uncompromising standards, they have generous carbide tips ensuring a long working life. These 216mm blades fit the Festool KS60 compound sliding mitre saw, but can of course fit any saw able to take this size. The W36 features 36 teeth, designed for cutting every type of wood and wood composite as well as building panels, gypsum fibre boards and soft plastic.
Blade Diameter 216 mm
Maximum RPM 5,000 rpm
Manufacturer Part Number 500124
Kerf 2.3 mm
Teeth 36
Tooth Format ATB
Plate Thickness 1.6 mm
Hook Angle 5 Negative Rake
Bore Size 30 mm
Web Attribute Set Circular Saw Blades - Power Tool
EAN Barcode 4014549212233
