Festool
Festool Wood Scoring Blade for TSV60 Plunge Saw
SKU: 110703
£44.98
£37.48 Excl. VAT
  • Specialist tool designed for use with coated or veneered chipboard
  • Diamond scoring saw blade scores the top layer of the material
  • Two diamond teeth enable splinter-free cuts on both sides
  • Conical tooth shape allows for easy adjustment of the scoring width
  • Extremely long service life
Your specialist tool for perfect, splinter-free cuts. The diamond scoring saw blade scores the top layer of the material, ensuring a splinter-free cut on both sides. Designed specifically for use with coated or veneered chipboard, the two diamond teeth enable splinter-free cuts, even in hard-to-machine materials.
Extremely long service life thanks to the use of diamond cutting teeth. The conical tooth shape makes it easy to adjust the scoring width to the saw cut.
Diameter 47mm, cutting width 1,95 - 2,5 mm, hole dia. 6.35 mm, teeth 2
Manufacturer Part Number 577962
Web Attribute Set Plunge Saws
EAN Barcode 4014549433065
