Mirka
Mirka Abranet Ace Delta Abrasives 100 x 152mm (Pkt 5)
SKU: 106542
£10.98
£9.15 Excl. VAT
  • Pre-cut to fit the Mirka Deos 663CV Delta sander
  • An incredibly efficient, ceramic grit, long lasting abrasive
  • Open mesh design eliminates clogging
  • Dust free sanding when used with extraction
  • 100 x 152mm pre-cut Delta sheets with hook and loop backing
  • Suitable for hard woods, GRP, MDF, metal, paint and composites
Suitable for the Mirka DEOS 663CV Delta sander, for dealing with tough and more demanding sanding applications. Abranet® Ace features a mesh backing coated with ceramic grit. It offers superior cutting performance on hard woods such as beech and oak as well various other solid surface materials. Abranet® Ace is also excellent for all paint sanding applications, with optimal performance and an enhanced life.
Supplied in packs of 5.
Abrasive Sheet Size 100 mm x 152 mm Delta
Abrasive Material Ceramic
Abrasive Type Abranet Ace
Abrasive Backing Mesh Hook and loop
Pack Quantity 5
Abrasive Grit 80
Web Attribute Set Abrasive Sheets
EAN Barcode 6416868734065
