Mirka
Mirka Delta Pad Saver 100 x 152mm (Pack 5)
SKU: 114477
£28.43
£23.69 Excl. VAT
  • Extends the life of your sander’s backing pad
  • Reduces wear when sanding edges and corners
  • Maintains consistent sanding performance
  • Hook & loop attachment for quick fitting
  • Ideal for professional and hobby use
  • High-quality Mirka durability
Extend the life of your sanding setup with the Mirka Delta Pad Saver 100 x 152mm. Designed to sit between your sander’s backing pad and abrasive, this simple but effective accessory helps protect against wear caused by continuous and aggressive sanding. Particularly suited to use with net abrasives, it ensures your tool maintains consistent performance while reducing the need for costly pad replacements.
This pack of five delta pad savers measures 100 x 152mm and features a hook & loop attachment for quick and easy fitting to compatible sanders, including Mirka DEOS Delta models. They act as a sacrificial layer, protecting the backing pad from wear and tear during intensive use while maintaining sanding efficiency. Designed to be replaced regularly, they provide a cost-effective way to prolong the life of your backing pad and keep your sanding system performing at its best.
Mirka is a globally recognised leader in abrasives and surface finishing solutions, known for its innovative approach and high-performance products. With decades of expertise and a strong focus on efficiency and durability, Mirka continues to develop tools and systems that deliver superior results for professional and enthusiast users alike.
Use with Mirka Abranet delta sanding sheets and Mirka DEOS Delta sanders for optimal performance.
Web Attribute Set Delta Sanders Accessories
EAN Barcode 6416868939217
