Mirka
Mirka Gold Abrasive Discs Multifit 125mm
SKU: 113880
£21.88
£18.23 Excl. VAT
  • Multifit hole pattern fits most backing pads to maximise dust extraction
  • Quality stearate coated, non-clogging 125mm abrasive disc
  • Long-life aluminium oxide grits
  • Suitable for soft and hard wood, MDF, paints, lacquer, plastics etc
  • Available in pack sizes of 10, 50 and 100
Mirka Gold hook and loop backed 125mm discs are a durable product very well suited for sanding at high speeds. Gold is an all-round sanding material suitable for many applications, including wood, paint, lacquers, non-ferrous metals and plastics.
The Multifit hole pattern is designed to fit most backing pads, ensuring maximum dust extraction when used with a compatible vacuum system. To achieve an optimal sanding result, the semi-open grit binding and special stearate coatings prevent clogging and pill forming.
Coarser grits are recommended for sanding putty and removing lacquer, while finer grits are excellent for dry sanding primed or lacquered surfaces in preparation for following coats.
Available in various Grits and pack sizes of 10, 50 or 100
Abrasive Type Gold
Abrasive Backing Hook and loop
Pack Quantity 50
Abrasive Grit 60
EAN Barcode 6416868265224
