Mirka
Mirka Pad Saver for Delta Sanders
SKU: 502531
£2.38
£1.98 Excl. VAT
  • Mirka 93mm pad saver for Delta sanders
  • Increases the life expectancy of Delta backing pads
  • Universal hole pattern
The use of a pad saver will considerably increase the life of your sander's backing pad and add a slight cushioning effect for more effective contour sanding. The Mirka pad saver also makes a more secure attachment for Abranet abrasive sheets to non-Mirka sanders.
Web Attribute Set Delta Sanders Accessories
EAN Barcode 6416868964387
