Mirka
Mirka Profile Interface Pad/Mirlon 81x133mm Kit
SKU: 113890
£19.58
£16.32 Excl. VAT
  • Precision sanding for profiles and contours
  • Memory foam adapts to profiles and resets after use
  • Delivers even sanding in hard-to-reach areas
  • Compatible with Mirka DEOS 353CV and other 81x133mm pad sanders
Achieve flawless finishes on doors, windows, and furniture with the Mirka Profile Foam Interface Kit. Designed to adapt to contours, grooves, and curved surfaces, the flexible memory foam pad ensures even pressure and consistent results - perfect for intricate sanding tasks.
Compatible with the Mirka DEOS 353CV and other sanders using 81 x 133 mm pads, the blade piece attaches securely to the sander while the white foam moulds to the surface profile. After use, the foam returns to its original flat shape, ready for the next job.
Supplied with five replaceable Mirlon Total® VF 360 abrasive sheets, this kit is ideal for de-nibbing and surface preparation. The abrasives offer excellent conditioning with a fine texture, delivering a smooth, high-quality finish.
Supplied with; 1 x Profile Foam Interface Pad (81 x 133 x 56 mm) and 5 x Mirlon Total VF 360 Abrasive Sheets.
N.B. Mirka Mirlon Finishing Pads 115 x 230mm in 360G (Code 502612) and 1,500G (Code 502613) are compatible but will need to be cut down to size.
Web Attribute Set Palm Sander Accessories
EAN Barcode 6416868980974
