The Multi-Sharp® unique Drill Bit Sharpener accurately sharpens the following drill bits: HSS (incl. titanium coated)Masonry (regular and hammer)SDS-PlusCentre-point wood (brad-point). 3-13mm diameter.It also re-edges and resharpens small tools : eg.scribers,bradawls,punches,cold chisels,screwdrivers,TCT tile and laminate cutters. Comes with high quality Aluminium Oxide and Silicon Carbide grinding wheels, which sharpen at least 150 HSS/Woodbits and 75 Masonry/SDS+ bits respectively (based on 6.5mm dia.). Grinding wheels are replaceable.
Powered by any electric drill.
