Shesto
Pigtail Mop Arbor 6mm Shank
SKU: 503936
£8.48
£7.07 Excl. VAT
  • Enables mops to be used in a power drill or flexible shaft
  • For use with leather centred mops
  • 6mm shank
  • Recommended mops no more than 100mm diameter
This pigtail arbor enables a leather centred polishing mop to be mounted in a power drill or flexible shaft. It has a 6mm shank to fit into the drill's chuck. Please note, when using a polishing mop in a drill or flexible shaft, it is recommended to use mops no more than 100mm in diameter.
Web Attribute Set Polishing Mop Accessories
EAN Barcode 5060030665995
