Head with precision milled dovetail slide may be tilted through 90
Fine feed selectable, allowing fine head feed for milling. With dial and depth scale. Geared rack and pinion feed for effortless drilling with 65mm stroke. 45mm diameter drill column, 500 mm long. Approximately 140mm throat. Machined, solid baseplate approx. 200 x 300mm. All drills with standard 43mm spindle collars may be utilised directly: Bosch, Metabo, Matika, Skil etc.
