Proxxon
PROXXON BFB 2000 Mill/Drill Stand
SKU: 474364
£222.07
£185.06 Excl. VAT
&#149 Milled adjustable dovetail slide &#149 Clear, easily legible depth scale &#149 45mm diameter column, 500mm long &#149 Adjustable zero position for fine feed &#149 Selectable fine feed with lever &#149 Stable, machined work top with T-slots &#149 Approx. weight 6.5kg
Head with precision milled dovetail slide may be tilted through 90° to give all-round versatility: diagonal drilling, versatile without the need of special milling bits, milling diagonal slots.
Fine feed selectable, allowing fine head feed for milling. With dial and depth scale. Geared rack and pinion feed for effortless drilling with 65mm stroke. 45mm diameter drill column, 500 mm long. Approximately 140mm throat. Machined, solid baseplate approx. 200 x 300mm. All drills with standard 43mm spindle collars may be utilised directly: Bosch, Metabo, Matika, Skil etc.
Rating Trade/Professional
Web Attribute Set Milling Machines Stands
EAN Barcode 4006274200005
