Proxxon
PROXXON Saw Blade for KS230E - 50mm x 0.56mm x 10mm 100T
SKU: 300109
£10.06
£8.38 Excl. VAT
&#149 Fine-toothed for precision cutting &#149 For the PROXXON KS 230E saw &#149 50mm diameter &#149 Spring steel saw blade &#149 10mm bore
50mm diameter Spring Steel Saw Blade with a 10mm bore, 0.5mm thick. Alloy holding a high proportion of tungsten, vanadium and molybdenum for an even structure, high hardness and long lifetime. Designed with fine teeth for precision cutting. For very fine cuts in non-ferrous metals (aluminium, brass, copper). Also suitable for cutting compound materials like PC cards, and sawing wood and plastics.
EAN Barcode 4006274280205
