Shaper
Shaper Connected Bluetooth Calipers
SKU: 110706
£175.00
£145.83 Excl. VAT
  • High precision calipers
  • Easily connect to Shaper Origin
  • Large multi-unit display
The Shaper Connected Calipers send precise measurements directly to your Shaper Origin. So, your projects will be more accurate - which is essential for any successful project - and there is less risk of unnecessary mistakes!
These calipers are easy to connect the Shaper Origin or any other bluetooth device - you can use them with your computer, phone and favourite CAD tool. Once connected, simply press the yellow button to send your measurement.
Accuracy is essential, and these calipers have an accuracy of 0.0254mm / 0.001in. They're range is 200mm / 8in and they are water and dust resistant - perfect for using anywhere, onsite and on the job. Measuring pockets and slots is simple and accurate with the included depth stop accessory. The large multi-unit display makes it easy to read your measurements, and you can switch between millimeters, inches and fractions easily.
Provided in a protective case, including depth stop, two batteries, battery compartment tool and certificate of inspection.
Web Attribute Set Measuring Calipers
