Shaper
Shaper Edge Morticing Adaptor for For Origins Plate
SKU: 110699
£109.00
£90.83 Excl. VAT
  • Enhance your Shaper Plate
  • Utilize vertical workholding
  • Easy to install, align and remove
The Edge Morticing Adaptor enhances the functionality of the Shaper Plate. Crafted from die-cast aluminium, this adapter enables vertical workholding on the Plate. It can be easily installed, aligned, and removed. While the adaptor itself does not include the Plate, it serves as a valuable addition for woodworking tasks. By attaching the Edge Morticing Adaptor to the Plate’s base in any one of three positions, woodworkers can achieve a reference face and clamping surface, perfect for installing concealed hinge door hardware, cutting awkward joinery and utilizing the Plate for other vertical workholding applications.
Easy to use: simply attach the Edge Morticing Adaptor to Plate's threaded holes, next attach to your workpiece using the two clamping faces on either end, and finally, begin cutting! With this accessory, your Shaper Origin and Plate are even more flexible and portable than before.
Web Attribute Set Router Jigs & Templates
