Shaper
Shaper Shelf Upgrade for Workstation
SKU: 113636
£198.00
£165.00 Excl. VAT
  • Over 3× larger than the standard Shaper Workstation shelf
  • Ideal for larger or more complex jobs
  • Adjustable support leg maintains a flat, stable surface under load
  • Fine-tune height adjustment ensures a coplanar surface with the Workstation
  • Compatible with manual Origin use or BenchPilot automation
  • Quick setup for a rigid, reliable work surface
  • Shelf dimensions: 410 × 280 mm (16.125 × 11)
  • Support leg range: 740 mm – 1140 mm (29 1/8 – 44 7/8)
Upgrade your Shaper Workstation with the Shaper Shelf Upgrade Kit – a robust, precision-engineered accessory designed to dramatically expand your horizontal cutting area. Whether you're routing manually with Origin or pairing it with BenchPilot, this kit provides a stable, coplanar surface that stays flat under load, helping you achieve cleaner, more accurate results.
Over three times larger than the standard shelf assembly, the Shaper Workstation Shelf Upgrade Kit is ideal for larger projects or when you simply need more support. The included adjustable support leg ensures the shelf remains level and rigid, even under demanding workloads. With both coarse and fine height adjustments, you can dial in a perfectly flat surface every time.
