Shaper
Shaper Up-Spiral O-flute Router Bit 3.175mm x 6.35mm 1/4" Shank
SKU: 109291
£33.00
£27.50 Excl. VAT
  • Ideal for non-ferrous metals and acrylic
  • Polished O-flute resists chip adhesion
  • Appropriate for a wide range of non-wood materials
The Shaper solid carbide O-flute bit is designed for cutting acrylics and non-ferrous metals; further extending the potential of the Shaper Origin. The polished flute prevents nasty chip build-up that can compromise cut quality and decrease cutter longevity. The geometry of the O-flute cutter offers excellent results in both acrylics and non-ferrous metals.
Overall Length: 63,5 mm (2.1/2)
Shank Diameter: 6,35 mm (1/4)
Cutter Diameter: 3,175 mm (1/8)
Cutter Length: 6,35 mm (1/4)
Geometry: Upcut, Spiral, O-Flute
Material: Solid Carbide
Web Attribute Set Spiral Router Cutters
