Shaper
Shaper Workstation
SKU: 108154
£450.00
£375.00 Excl. VAT
  • Vertical and horizontal workholding capabilities
  • Secure small and difficult to fixture workpieces
  • Make perfect mortice and tenon joinery, box joints and more
The Shaper Workstation aligns and clamps your work with speed and precision. The Workstation is the ultimate benchtop accessory for the Shaper Origin handheld CNC router. The Workstation is designed to streamline your workflow and expand the Shaper Origin’s abilities by offering rapid, repeatable and precise clamping of a wide range of workpiece configurations. The Workstation features a reusable ShaperTape field, an easily adjustable Shelf for small or difficult to clamp workpieces, indexing pins for easy alignment and registration, and an angle fence for aligning stock quickly at exact angles. These features greatly reduce setup time and make it easier than ever to start cutting quickly. The clamping face features 4 T-Track grooves which will accept any clamp compatible with 8mm T-Track .Workstation includes two T-Track clamps.
Overall W 515mm x D 465mm x H 250mm, weight: 9.75kg.
