Souber
Souber Long Clamp Screws (Pair)
SKU: 107229
£9.28
£7.73 Excl. VAT
  • Fits Souber JIG1 or Souber JIG2 Offset Morticer
  • Use on door frames 100 mm to 200 mm wide
  • Helps when cutting hinges and strikes on door frames
These extra long clamping screws enable you to use the Souber JIG1 or Souber JIG2 Offset Morticer on door frames and posts between 100 mm to 200 mm wide. Use when cutting hinges and strikes on door frames. For best results use when there is no architrave.
The extra long clamping screws allow full left to right movement from 100 mm to 135 mm. Above, 140 mm the left to right movement will start to reduce as the jig opens towards 200 mm wide.
Web Attribute Set Drilling Guides
EAN Barcode 5060082786747
