Spraycraft
SprayCraft Portable Foldaway Spray Booth
SKU: 103876
£122.98
£102.48 Excl. VAT
  • Provides a clean, versatile and safe environment for airbrushing
  • Quiet motor and fan produces strong airflow; filter absorbs overspray
  • Integral LED light; revolving turntable, allows 360 access
  • 3-way switch for fan and light control
  • Open: 405 x 475 x 335mm; closed: 405 x 215 x 290mm
  • Noise level 45db, weight 5kg
A versatile foldaway spray booth supplied with 2.5m of ventilation hose, easy change filters, integral LED light and a large turntable.
The SprayCraft spray booth provides a clean and safe environment when using an airbrush. The hose is more than long enough to position through an open window if wished. When open, a bright LED light generously illuminates the working area. The easily changed, high-density filter absorbs paint and moisture. The quiet motor and fan produces a strong airflow, capturing and filtering any overspray, mist and vapour. The large 220mm diameter turntable gives a full 360 access to the subject.
When not in use the spray booth folds neatly for storage; a carrying handle provides easy portability. It is ideal for model making, automotive customising and touch-up, crafting, cake decorating, designing, illustrating or renovating and restoring.
Additional Accessories No
Web Attribute Set Air Brush Accessories
EAN Barcode 5060252024525
