Starrett
Starrett Fastcut Bi-Metal Holesaws
SKU: 112365
£24.43
£20.36 Excl. VAT
The Starrett Fast Cut Bi-Metal Holesaws provide a smoother, faster cut on a wide range of materials, when compared to the previous constant pitch saw. Improved tooth material and 5.5 TPI/25mm tooth form for enhanced heat and wear resistance and greater product life. Specifically suited to cutting stainless and mild steel sheet, they will also cut through tubes with a wall thickness of up to 3mm (1/8in). Specification: Cutting Depth: 41mm.
Holesaw Diameter 102 mm
Web Attribute Set Holesaws
EAN Barcode 7891265005267
