TSO Products
TSO Narrow Stock Pro Rip System Supports
SKU: 113726
£207.28
£172.73 Excl. VAT
  • CNC-machined Gage Bars for repeatable cuts
  • Guide Rail Supports prevent tipping and sagging
  • Quick calibration for consistent results
  • Easy to store and transport
  • Fits Festool, Makita, Milwaukee, RIDGID, Kreg ACS, Powertec, Eastvolt
Make narrow cuts with Track Saw precision!
Track saws excel at wide panels, but when it comes to narrow cuts, they can fall short - until now. The TSO Narrow Stock Pro solves the problem with two Guide Rail Supports that keep your rail flat and stable, and two CNC-machined Gage Bars that create a precise, repeatable fence. Whether you’re cutting face frames, trim pieces, drawer parts or spacer blocks, this system delivers cabinet-saw accuracy in a compact, portable setup.
Unlike full parallel guides, Narrow Stock Pro is quick to calibrate and easy to store, yet just as precise. It’s ideal for Festool MFT/3 benches, custom 20mm workstations, or even portable cutting on insulation foam or MDF. Adjustable for deeper cuts up to 1.5, it’s engineered for flexibility without sacrificing accuracy—making it the perfect solution for small workshops or on-site jobs.
Compatible with Festool, Makita, Milwaukee, RIDGID, Kreg ACS, Powertec and Eastvolt guide rails, Narrow Stock Pro works wherever your track saw goes. Compact, accurate and ready to go, it’s the next best thing to a cabinet saw or bandsaw, without the bulk.
Supplied with: 2 Gage Bars, 2 Guide Rail Supports, 4 Flathead Screws.
