TSO Products
TSO Parallel Guide System Tracks 50" Gen 2 (Pair)
SKU: 114002
£139.78
£116.48 Excl. VAT
  • Universal tracks: No left/right - simpler, faster setup
  • Dual scales: Imperial & metric, laser-engraved for accuracy
  • Quick-change: Works with Drop-Loc Connectors (not included)
  • 50 length
The Parallel Guide Tracks are the backbone of the Parallel Guide System Gen 2. Redesigned with customer feedback, each track is now universal - no more “left” and “right” to keep straight. Setup is simpler and faster, with no second-guessing.
These are used with the Drop Lock Connectors (not supplied). These single-piece aluminum guides feature dual Imperial and Metric high-contrast, laser-engraved scales for fast, accurate readings. They lock firmly to your guide rail with the Drop-Loc Connector, yet reposition or remove in seconds when it’s time for the next cut. Both the new 2025 Flip Stop Pro and the original Flip Stop (v1 and v2) are fully compatible with Gen 2 Parallel Guide Tracks.
50 Parallel Guide Tracks – Max Rip: 50
When you need capacity for larger builds: kitchen islands, built-ins, workbench cabinets, or commercial casework.
Please note these tracks use Drop-Loc connectors Gen 2 or guide rail adaptors to connect to guide rails.
