UJK
UJK Adjustable Universal Countersink
SKU: 112026
£21.68
£18.07 Excl. VAT
  • Countersink ensures clean cutting and efficient chip removal
  • Very smooth clean finish
  • Works with wood twist drills from 3mm to 8mm
  • Tungsten carbide-tipped cutting edges for durability
  • Handles softwood, hardwood and man made boards
  • Suitable for use with power tools and drill presses
The UJK TCT Adjustable Countersink is a versatile, high-performance tool, engineered to deliver clean, precise, and efficient results, making it an essential addition to any toolkit.
The countersink is suitable for use with wood twist drills ranging from 3mm to 8mm, allowing for drilling and countersinking/counterboring in a single operation. It can be used with both power tools and drill presses, making it suitable for various applications and setups. The countersink's design ensures clean cutting and efficient chip removal, resulting in smooth and precise holes every time.
A notable feature of the UJK TCT Adjustable Countersink is its tungsten carbide-tipped cutting edges. These edges are designed to handle a variety of materials, including softwood and hardwood, ensuring durability and longevity.
The UJK TCT Adjustable Countersink is incredibly versatile, thanks to its adjustable design. It can easily be adjusted to fit different drill bit sizes by simply unscrewing the two hex head securing bolts and placing it over the desired drill bit. This makes it ideal for creating countersinks and counterbores of different diameters, offering flexibility and convenience for a variety of woodworking projects.
Whether you're working on intricate projects or large-scale tasks, this countersink is designed to meet your needs with reliability and ease.
Intended Use Designed to create a conical hole that accommodates the head of a screw.
Web Attribute Set Countersinks
EAN Barcode 5052511137572
