Out of Stock
UJK
UJK Blank Universal Sub-Base
SKU: 110223
£23.98
£19.98 Excl. VAT
  • Customisable base, fits all routers
  • Increased safety and stability when handheld routing
  • Drill your own countersunk holes to fit your router model
  • Phenolic sub base increases stability and torsion resistance
  • Machined to high tolerances for perfect accuracy
  • Accepts euro style guide bushes and adaptors
  • Made in Britain
Arguably the most useful routing accessory you'll add to your workshop; the UJK Blank Universal Sub Base. This base will help you to work safely, provides stability and increases accuracy when handheld routing. Unlike some other models, there are no pre drilled holes, therefore it is completely customisable and will fit all router models. Some routers can be difficult to match up with suitable guide bushes and a universal sub-base can be the only solution. Simply drill your countersunk holes in the centre using our UJK Centring Cone (available in metric and imperial) and your router will fit with any of our UJK guide bushes.
Made in Britain Yes
Web Attribute Set Router Jigs & Templates
EAN Barcode 5052511132942
