Arguably the most useful routing accessory you'll add to your workshop; the UJK Blank Universal Sub Base. This base will help you to work safely, provides stability and increases accuracy when handheld routing. Unlike some other models, there are no pre drilled holes, therefore it is completely customisable and will fit all router models. Some routers can be difficult to match up with suitable guide bushes and a universal sub-base can be the only solution. Simply drill your countersunk holes in the centre using our UJK Centring Cone (available in metric and imperial) and your router will fit with any of our UJK guide bushes.
UJK
UJK Blank Universal Sub-Base
| Made in Britain | Yes |
| Web Attribute Set | Router Jigs & Templates |
| EAN Barcode | 5052511132942 |
