UJK
UJK Edge Breaking Router Cutters - 8mm Shank
SKU: 112154
£21.98
£18.32 Excl. VAT
  • Create a flawless woodworking finish
  • Ensures perfect arris removal for a clean, professional look.
  • Manufactured from EN8 steel, coated with Xylan to reduce friction, prevent build-up, and extend lifespan
  • Essential prior to applying paint or varnish
  • Available in 8mm shank and multiple radii (1mm to 6mm) for exact and controlled rounding
  • Proudly designed and made in Britain
The UJK Edge Breaking Router Cutter, the ultimate tool for achieving a flawless finish on your woodworking projects, this cutter is designed to deliver precision and reliability every time.
Don’t leave a sharp edge of wood unfinished! A sharp edge or corner can be uncomfortable to handle, may splinter, and will not take a finish well. Rounding over sharp edges or creating a slight chamfer on an edge, known as removing the arris” will solve these problems.
The British made, UJK Edge Breaking Router Cutter, allows you to can achieve exact and controlled rounding. Unlike standard rounding over cutters, the UJK Edge Breaking cutter has cutting edges that gradually recede from the radius at the top and near the bearing to ensure no corner lines remain. Available in 8mm or 1/4 shank and in multiple radii from 1mm, 1.5, 2, 3, 4, 5 and 6mm, this cutter ensures perfect arris removal, giving your work a clean and professional look.
As the UJK Router Cutter range grows, all UJK cutters are proudly designed and made in Britain. Manufactured from EN8 steel and coated with Xylan to reduce friction, prevent build-up, and extend the cutters lifespan. UJK's commitment to innovation is evident in every detail of this router cutter.
Shank Diameter 8 mm
R = Radius 1 mm
Intended Use Used to produce a moulding or profiled edge.
Web Attribute Set Ovolo & Rounding Over Router Cutters R: 1
EAN Barcode 5052511138555
