UJK
UJK Mitre Fence & T-Slot Track 800mm
SKU: 101766
£40.88
£34.07 Excl. VAT
  • Aluminium extrusion combines two tracks into one
  • Takes a mitre gauge with a 3/4 x 3/8 bar without a T-slot washer
  • T-track slot works with standard 1/4 hex head bolts and T-nuts
  • Anodised for wear resistance and lower friction
  • Offers great potential when building a router table
  • See User Manual Download for dimensioned drawing
This anodised aluminium extrusion from UJK combines a mitre fence track and T-track into a single length. The mitre fence track takes a mitre gauge with a 19mm x 9.5mm (3/4 x 3/8) bar without a T-slot washer. The T-track slot works with standard 1/4 hex head bolts and UJK 6mm T-nuts, allowing you to use hold downs, feather boards and self-made jigs. The anodising increases wear resistance and lowers friction. If building your own router or drill press table this combined track gives greater potential to the finished item. See User Manual Download for dimensioned drawing.
Web Attribute Set Router Accessories & Hardware Track Length: 800 mm
EAN Barcode 5052511064724
