UJK
UJK Parf Guide System Mk II Centrotec Shaft & 3mm Drill
SKU: 107893
£17.58
£14.65 Excl. VAT
  • Spare or replacement UJK Parf MkII drill bit holder
  • Universal 1/4" hex shank with CENTROTEC design
  • High quality 3mm drill bit
This drill bit holder and 3mm drill bit is part of the UJK Parf MkII Guide System. It is used in conjunction with the bearing guided 3mm drill Guide and UJK Parf Sticks for the initial laying out of the grid of dog holes. The shank is 1/4 hex universal fitting suitable for all 1/4 hex quick change systems including the Festool CENTROTEC and 3-jaw drill chucks. This bit will help you produce dozens of UJK Parf Guide bench tops.
Made in Britain Yes
Intended Use Used in conjunction with the Parf Guide System to produce dog holes.
Web Attribute Set Wood Boring Bits
EAN Barcode 5052511126040
