Make your own pocket hole plugs. Simply use the plug cutter in a pillar drill to create you own plugs using matching or contrasting timber, glue them in, trim using a flush cut saw and sand to a finish. Cuts 9.5mm (3/8
UJK
UJK Pocket Hole Plug Cutter
| Web Attribute Set | Plug Cutters & Plugs |
| EAN Barcode | 5052511062768 |
