UJK
UJK Portable Plate for Pocket Hole Jig
SKU: 503802
£9.78
£8.15 Excl. VAT
  • Developed for the UJK Pocket Hole Jig
  • Portable plate, take the jig to your work
  • Great for restoration work
  • Simple to fit, just remove the jig from the base and fit
  • Best used with UJK Locking C Clamp
Especially developed for the UJK Pocket Hole Jig, this plate allows you to take the jig off the bench mounted unit and use it as a portable jig. Especially useful for restoration work or joints that need to be worked where you cannot clamp whilst working on a bench. Best used with the UJK Locking C Clamp. Note, finish may be black or bright.
Made in Britain Yes
Intended Use Converts the UJK Pocket Hole Jig for use it as a portable jig.
Web Attribute Set Pocket Hole Jigs & Accessories
EAN Barcode 5052511066667
