UJK
UJK Progrip Side by Side Adaptors
SKU: 103891
£24.58
£20.48 Excl. VAT
  • Join 2 UJK Progrip clamps side by side
  • One clamp grips bench with second clamp inverted
  • Grip workpieces across the top for sanding etc
  • Supplied as a pack of 6, sufficient for 2 pairs of clamps
These adaptors join 2 UJK Progrip clamps side by side. The adaptors lock into the clamp’s T-slot anywhere along the length allowing you to join clamps of different lengths.
One clamp firmly grips the top of your bench, in the normal position. The second clamp is in an inverted position, allowing you to grip workpieces above your bench in the jaws of the second clamp. One great advantage is that the underside of your workpiece has a wider area of support.
Supplied in a pack of 6, sufficient for 2 pairs of clamps.
Additional Accessories No
Web Attribute Set Power Tool Accessories
EAN Barcode 5052511099955
