UJK
UJK Progrip Stop Block
SKU: 103890
£15.18
£12.65 Excl. VAT
  • Easily fixed to the UJK Progrip clamp’s T-slot
  • Limits travel of the tool, for stopped cuts etc
  • Guarantees precise repeat cuts
  • CNC machined from solid nylon
The UJK Progrip Stop’s main use is to limit the travel of your router and ensure precise repeat cuts when cutting stopped grooves, panel mouldings repeat cuts etc.
CNC machined from a solid block of engineering nylon it measures 125mm x 50mm x 20mm. The stop runs in the T-slot of your Progrip guide and locks with a simple threaded knob anywhere along the length.
Additional Accessories No
Web Attribute Set Power Tool Accessories
EAN Barcode 5052511099962
