UJK
UJK Replacement Bit for Pocket Hole Drill (Pair)
SKU: 111919
£6.68
£5.57 Excl. VAT
  • Replacement tips for the UJK Pocket Hole Drill with 12mm Bit
  • Available in sizes 30mm / 22mm / 12mm
  • Manufactured from M2 steel
  • No need to buy a whole new drill bit when the tips break
Replacement tips for the UJK Pocket Hole Drill with 12mm Bit, manufactured from M2 steel and available in sizes 30mm / 22mm / 12mm.
Broken the tip off your UJK Pocket Hole drill? No need to buy a whole new drill bit! The UJK Pocket Hole Drill with 12mm Bit allows interchangeable and replaceable tips.
Overall Length \ Working Length 12 mm
Intended Use Drill bit for use with pocket hole jigs.
Web Attribute Set Wood Boring Bits
EAN Barcode 5052511136704
