UJK
UJK Router Inlay Kit
SKU: 113587
£35.48
£29.57 Excl. VAT
  • Create decorative inlays or repair wood flaws with precision
  • Ideal for disguising cracks, and blemishes
  • Delivers professional results using templates
  • British-made ensuring durability and accuracy
  • Includes: 7.5mm & 13.5mm stainless steel guide bushes, 3mm solid carbide down-cut spiral cutter, and securing ring
  • Available in 1/4 and 8mm shanks
The UJK Router Inlay Kit is a versatile solution for adding decorative inlays or disguising minor flaws in wood surfaces. Designed to work with your router, this high-quality inlay kit allows you to create intricate designs using templates, enhancing your projects with professional results. It's also an ideal solution for repairing defects; simply cut a matching wood inlay to fit seamlessly into knots, cracks, or blemishes, restoring the surface flawlessly.
Proudly British made, each component is carefully manufactured for durability and accuracy, ensuring a reliable performance every time. The kit complements your collection of UJK Router bits, making it an essential addition to any woodworking setup.
Kit supplied with: 1 x 7.5mm stainless steel guide bush, 1 x 13.5mm stainless steel guide bush, 1 x 3mm solid carbide down-cut spiral cutter and 1 x securing ring.
Available in 1/4 and 8mm shanks.
Shank Diameter 8 mm
EAN Barcode 5052511143023
