Out of Stock
UJK
UJK Router Table Insert for Trend T14
SKU: 112999
£99.98
£83.32 Excl. VAT
This 10mm UJK Router Table aluminium insert plate is pre drilled specifically for the Trend T14 1/2 Router, for router tables measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. The insert plate will accommodate the Trend T14 1/2 Router with pre-drilled holes to fit perfectly. It is supplied with a removable central insert ring with a 38mm diameter hole with a range of other hole sizes available. This includes one that will accept a standard threaded guide bush for template routing. The UJK router table insert for Trend T14 will also fit: Trend: T8E, T10E, T11E, T12E, T14E Elu: MOF177E DeWALT: DW625E, DWE625E, DW262E CMT: CMT1E, CMT2E
Intended Use Table insert for securing a router to your router table.
EAN Barcode 5052511141036
