UJK
UJK StepPower HSCO Drill Bits
SKU: 112957
£4.98
£4.15 Excl. VAT
  • Suitable for metal work and high-precision woodworking
  • Multi-Step Drill Design for precision and effortless drilling
  • Unique step geometry ensures material is gradually removed
  • Split Point Geometry for precise centring and easy cutting
  • High wear resistance and durability
  • 3-Flat Shank prevents slipping in the chuck
The UJK StepPower HSCO Drill Bits are engineered to deliver exceptional drilling performance, making them an indispensable tool for both metalworking and fine woodworking.
Due to the step design there is no need to pre drill or punch making these by far easier to use especially in metal drilling. The step geometry gradually removes waste until the diameter is achieved of the drill bit, ideal for use in cordless and hand held drills. Their precision and sharpness also make them effective for hardwoods. This innovative design not only enhances accuracy but also reduces splintering and tear-out, providing a smooth finish.
The UJK StepPower HSCO Drill Bits are made from 5% cobalt high-speed steel (HSCO), offering superior wear resistance and durability. This robust material ensures that the drill bits can withstand the rigours of heavy-duty use, maintaining their sharpness and effectiveness over time. The 3-flat shank design prevents slipping in the chuck, guaranteeing exact circular holes every time.
Whether you're a metalworking, woodworking or both, the UJK StepPower HSCO Drill Bits are designed to meet your needs with unparalleled efficiency.
Drill Bit Diameter 3.0 mm
Overall Length \ Working Length 61 mm 30 mm
Intended Use Produces precision holes in metal, hardwood and plastics.
Web Attribute Set Sheet Metal Drilling
EAN Barcode 4049844506220
