Keep your UJK cutting and clamping accessories securely and neatly stored, when not in use. This is an empty T-LOC case with a foam insert. The insert has cutouts for UJK Cam Clamps, Wedges, Back Stops, Dog Rail Clips, Guide Pups, Guide Dogs and the Chamfer Tool. Dimensions: 396mm long x 296mm wide. Please note: this is the same case as supplied with the UJK Work Holding Accessory Kit.
UJK
UJK T-Loc Case & Foam Cutout For Work Holding Accessories
| Intended Use | Storage case for use with the UJK Parf Dog accessoires. |
| Web Attribute Set | Organiser Cases |
| EAN Barcode | 5052511119288 |
