UJK
UJK Work Top with Track for T-Loc Systainer Cases SYS3
SKU: 108497
£104.58
£87.15 Excl. VAT
  • Turn your T-LOC SYS3 or SYS2 case into a mini workstation
  • Indispensable when working on site or domestic situations
  • Takes bench dogs, UJK Cam Clamps, UJK hold downs and more
This useful worktop fits securely onto the top of your Festool SYS3 or SYS2 T-LOC cases. It provides you with a generous work area of 750mm x 430mm. The worktop is made from 18mm thick Valchromat, the same material as used for the UJK Multifunction bench tops.
This handy worktop effectively turns your T-LOC case into a very versatile, portable workstation. Not only Festool but also T-LOC cases from Mirka, Fein, Lamello and Tanos, as well other branded cases.
It features the MFT arrangement of 20mm dog holes at 96mm centres to take bench dogs, UJK Cam Clamps and other UJK accessories. In addition, a length of T-Track provides potential for various UJK hold downs and doubles as a 'going bar' when sawing.
This worktop will be invaluable when working on site or in domestic situations without access to a full size bench.
A finish can be applied to add extra protection to the top.
Length 750mm x width 430mm.
This worktop is certified by the Pan European Forest Council (PEFC).
Table Size 750 mm x 430 mm x 18 mm
Made in Britain Yes
Web Attribute Set Portable Work Benches & Trestles
EAN Barcode 5052511127368
