The Veritas Domino Joinery Table effectively turns your Festool DF 500 Domino into a fixed morticer. Rather than taking the Domino to the work, the table enables you to bring the work to the tool. This gives you a major advantage especially when working with smaller pieces. The table’s fences form a reference for the work allowing you to make repeatable and accurate placement of Domino mortices. The Veritas Domino Joinery Table ensures that the mortice is placed precisely in both sides of the joint for a perfect result every time. The table’s clamping options secure the workpiece in place while making the mortice with the Domino.
The Baltic birch laminated top is 800mm x 800mm overall (working area 800mm × 590mm) and mounted on a 100mm high base unit. The base unit has cutouts for clamping to a bench top. Your Domino mounts in the gap between the aluminium fixed fences. The table features four keyhole slots running parallel to the fixed fence for the hold-downs. The moveable guide fence accurately locates the workpiece at 90
Two 6mm shims are included for centering the mortice in the edge of standard 19mm(3/4
Includes 2 x aluminium fixed fences, a 90/45 guide fence, 2 x 6mm thick shims, offset gauge, 2 x hold-downs, 2 x brass knobs and assembly hardware.
Some self assembly required (Festool Domino Jointer DF 500 not included).
Made in Canada.
