The Einhell TP-BS 18/457 Li BL - Solo Belt Sander is a practical tool for evenly sanding large areas. Its brushless motor and electronic speed control are ideal for material and usage-oriented work, providing more control and power. There is also a continuous running lock for comfortable working.
The handle and additional handle with soft grip provide optimal handling. With tool-free belt adjustment and lock leaver for quick belt change. It also features an integrated storage surface for stationary use.
Supplied with: 3 x P80 Sanding Belts, 1 x Dust Box and 1 x Dust Extraction Adaptor.
Powered by Lithium-ion rechargeable batteries with a battery management system for a long-life.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Supplied as body only (no battery or charger).
Specifications:
Belt Speed: 120-250/min.
Belt Size: 75 x 457mm.
Sanding Surface: 75 x 126mm.
Weight: 2.58kg.
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 104.2 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Abrasive Belt Size 75 mm x 457 mm
Sound Pressure Level LpA [Uncertainty K] 93.2 dB(A) [3.0 dB]
Web Attribute Set Cordless Sanders
EAN Barcode 4006825663624
