The WV-380s are, by design, wet or dry vacuum cleaners that perform totally without compromise in either mode. When you want to operate as a dry machine performance must be as good as a dry-only machine, with big filters and the option of giant HepaFlo disposable dust bags ensuring a high standard of operation. Similarly, when required for wet work, a quick switch of the dry filter for the wet float valve and a change of floor nozzle will give you equally professional performance and a clean, dry floor at the end of it all. Extremely ruggedly built, with Numatic's patented Structofoam container and amply powered by a 1,200W "Twinflo" motor.
Supplied with Numatic AA12 Aluminium MultiFlo 32mm Accessory Kit which includes 2.4m Nuflex hose, aluminium extension tubes, dry nozzle and wet pick up nozzle.
