The Einhell TE-PS 165 Plunge Saw is easy to use, sawing depth and tilt angle adjustment are performed without tools. Enables precise cuts to be made at tilt angles of 45° to 90°. Straight results are assured by the parallel stop and a blade lock makes it easy to change the saw blade.
A large handle helps prevent fatigue when working. Whilst the vision panel provides a better view of the cutting area. Fitted with a four meter cable for an extra large radius of operation. There is also a handy vacuum extractor adaptor that helps you to keep the work space clean whilst you work.
Supplied with: 1 x High Quality HW/TCT Saw Blade 165 x 20mm x 48T.
Guide rail system is available separately.
Specifications:
Input Power: 1,200W.
No Load Speed: 5,200/min.
Depth of Cut: @90º 56mm, @45º 42mm.
Blade: 165 x 20mm Bore.
Weight: 4.75kg.
Max Depth of Cut @ 45º 42 mm
Max Depth of Cut @ 90º 56 mm
Blade Diameter 165 mm
Sound Power Level LwA [Uncertainty K] 102 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 91 dB(A) [3.0 dB]
Motor Power 1,200 W
Web Attribute Set Plunge Saws
EAN Barcode 4006825629668
