The TSC 55 KEB runs on either one or two 18V batteries and uses a 1.8mm kerf blade. With both batteries and the narrow kerf it performs at up to twice the speed of previous models. The thin blade guarantees perfect cutting quality with maximum performance.
A unique kickback stop protects you and your workpiece. It minimises the risk from kickbacks when plunge cutting, stopping the blade in the blink of an eye.
The brushless EC-TEC motor combined with two batteries makes the TSC as powerful as a mains-powered machine.
Dust control is into a collection bag or connection to a suitable extractor via Bluetooth® for virtually dust-free work.
A transparent viewing window gives a good view for the start and finish of a plunge cut. A detachable splinter guard in front of the blade, offers a virtually splinter-free finish on both sides of the work. Angle adjustment from -1 to 47 allows a slight undercut for perfect butt joints. The cut line remains the same no matter what the cutting angle. The slimline housing allows you to make cuts as close as 12mm.
Supplied with 42 tooth thin kerf blade and Systainer SYS3 M 337 carry case. Part of the Festool 18V family of tools.
This is a body only tool supplied without a battery or charger.
Battery Voltage 36 V (2 x 18 V)
Dust Extraction 27 mm / 36 mm Outlet
Max Depth of Cut @ 45º 43 mm
Max Depth of Cut @ 90º 55 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 160 mm
Sound Power Level LwA [Uncertainty K] 106 dB(A) [5.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 95 dB(A) [5.0 dB]
Vibration Cutting Wood [Uncertainty K] <2.5 m/s² [1.5 m/s²]
Saw Blade Speed 2,650 - 3,800 rpm (with 1 x 18V batt) 2,650 - 5,200 rpm (with 2 x 18V batt)
Manufacturer Part Number 576712
Web Attribute Set Cordless Circular Saws
EAN Barcode 4014549373514
